BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
Use this procedure to display global configuration information for BFD.
  1. To enter User EXEC mode, log on to the switch.
  2. Display global BFD configuration information:
    show ip bfd [vrf WORD<1-16>] [vrfids WORD<0-512>]
The following example displays global configuration information for BFD on an IPv4 interface.
Switch:1>show ip bfd
                         BFD information - GlobalRouter
                      BFD Version :  1
                     Admin Status :  TRUE
                      Trap Enable :  FALSE
   Total session number :  1
    UP: 1, DOWN: 0, AdminDown: 0, Init: 0
The following table defines parameters for the show ip bfd command.
Variable
Value
vrf WORD<1-16>
Specifies a VRF instance by VRF name.
vrfids WORD<0-512>
Specifies a VRF or range of VRFs by ID.
